First post, by Kanangea
when i put mount c c:\dosprog on dosbox 0.62 it says directory c:\dosprog doesn't exist what do i do ive been trying for more than 1 hour!!!!!! 😵
oh yeah and im trying to get duke nukem 3d to work
Are you sure that the directory exists? i have never heard about any problem with simple mounting like this...
Also post in the proper forum next time and choose better title.
Mirek
what do you mean by directory??
uhm c:\dosprog
The directory in question is the dosprog directory on C:\
you might want to try this
mount c c:\
Water flows down the stream
Kanangea, download one of the DOSBox frontends (e.g. D-Fend or Boxer) and use that to configure DOSBox with. I think a user-friendly, graphical frontend will make it much easier for you to use DOSBox.
_________________
directory = folder
On the ms-dos era, directories were called, you guessed it, DIRECTORIES. When Windows O.S. became commonplace, they insisted on calling them FOLDERS. 😁
i'm dowmloading d-fend right now so it will make dosbox easier to install and play duke nukem 3d right?
im not allowed to install it because its not my computer it is my parents
if the directory doesn't exist do i manually make the folder and then put it on 0.62 dosbox?
wwhhhhhoooohooooo i finally think it is working but i did the same thing before but it only works this time
