First post, by Kanangea
when i put mount c c:\dosprog on dosbox 0.62 it says directory c:\dosprog doesn't exist what do i do ive been trying for more than 1 hour!!!!!! 😵
Reply 1 of 10, by Kanangea
oh yeah and im trying to get duke nukem 3d to work
Reply 2 of 10, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Are you sure that the directory exists? i have never heard about any problem with simple mounting like this...
Also post in the proper forum next time and choose better title.
Mirek
Reply 3 of 10, by Kanangea
what do you mean by directory??
Reply 4 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
uhm c:\dosprog
The directory in question is the dosprog directory on C:\
you might want to try this
mount c c:\
Water flows down the stream
Reply 5 of 10, by MiniMax
Rank Moderator
Moderator
Kanangea, download one of the DOSBox frontends (e.g. D-Fend or Boxer) and use that to configure DOSBox with. I think a user-friendly, graphical frontend will make it much easier for you to use DOSBox.
_________________
Reply 6 of 10, by eL_PuSHeR
directory = folder
On the ms-dos era, directories were called, you guessed it, DIRECTORIES. When Windows O.S. became commonplace, they insisted on calling them FOLDERS. 😁
Reply 7 of 10, by Kanangea
i'm dowmloading d-fend right now so it will make dosbox easier to install and play duke nukem 3d right?
Reply 8 of 10, by Kanangea
im not allowed to install it because its not my computer it is my parents
Reply 9 of 10, by Kanangea
if the directory doesn't exist do i manually make the folder and then put it on 0.62 dosbox?
Reply 10 of 10, by Kanangea
wwhhhhhoooohooooo i finally think it is working but i did the same thing before but it only works this time
