First post, by evilk_venomslegions
Dear friends hi,
I've recently found out about DOSBox, since I needed an emulator to run some Greek DOS based programs in the accounting area, where I work.
Unfortunately I can't seem to make the program either view or write Greek.
I am running WinXP Professional on a PIV 2.2.
I have tried to change Config.NT to make it load grkeyb.com, but it's not a good solution as the program some times opens and some times doesn't.
Any good advise that I can use? DOSBox is a great solution and I want to work inside this environment, as it's quite easy and recommendable.
Thanks in advance for any help.
Evil.K.
