SCORE under DosBox
First post, by regelemarcel
Greetings. I have been successfully using DosBox for many years, in order to run an old DOS based music notation application called SCORE. I am using DosBox on a Mac, running the latest system (Catalina 10.15.6). WIth recent updates to my Mac, I am no longer able to run SCORE. I am able to launch DosBox just fine, and I can launch SCORE as well. But as soon as I open a SCORE music file, I get this error: "run-time error M6203: MATH" and the next line is "- ** : OVERFLOW error". Any guidance would be greatly appreciated!
-Marc
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
Hmm that is odd. I recall that error is from a slur sign and was related to something in the fpu emulation.
Can you send me an email on the email listed on https://www.dosbox.com/crew.php ? Will see if I can help you out. (will need a file with slur in it if it is indeed the problem I am thinking off, as I am unsure why it wouldn't work with the latest mac build)
(also try a file without a slur to see if that is indeed the problem)
Water flows down the stream
Reply 2 of 6, by regelemarcel
Thanks so much, I am emailing you a file with a slur in it. You are indeed correct, it is only crashing with files that have slurs. Are there any setting in the config file that you have found to fix this? Really appreciate your help, thanks so much!
marc
Reply 3 of 6, by _Rob
Assuming the program can run without an FPU (Floating Point Unit, aka x87 co-processor), you can try to get it to run with
[cpu]
fpu=false
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
the matter was already solved by email. All is fine now
Reply 5 of 6, by music_scoring
Could you please post the fix/workaround for this problem in the thread? I am also trying to use SCORE and am having the exact same problem. Thank you.
