First post, by lwc
v0.7 introduced the "core=auto" and "cycles=auto" options, which is great, but is there a way to actually know what does it use in a given game?
For "cycles=auto", at worst I can at least use ctrl+f11 and ctrl+f12 and therefore know indirectly.
Reply 4 of 10, by lwc
Where do you see "realmode" or "pmode" in the title? I just see "Dosbox 0.70, Cpu cycles: X, Frameskip Y, Program: Z". The status window too mentions nothing about the core.
Besides, don't forget there's also a "simple" mode.
Reply 8 of 10, by kruwi
If you run a protected mode game/app, core=auto automatically switches the core used to dynamic, whereas with real mode games/apps, the core being used will be "normal".
That's it, at least as far as I (And I'm only an "Alpha Tester" 😉 😉 ) have understood this.
Visit the end of the internet: www.groskreutz.de
Reply 9 of 10, by lwc
As I'm playing with it, it seems to me if auto is dynamic, then cycles are in percents (where "max"=100%) and if auto is normal, then cycles are in static numbers (the default is 3000).
Is this the way to know what's auto?
And what about the "simple" core (see above quote from the CONF file)?
Reply 10 of 10, by wd
Rank DOSBox Author
DOSBox Author
No, that's the way to know when the core guessing switched from
the normal core to the dynamic core or back.
Has nothing to do with this.
