First post, by GBlue
Hey I've got a Problem with the Mouse in DosBox.
The Mouse is too fast.
First I Thought it was only a problem within the game "Master of Magic".
But iI realized that it is in every game the same.
If I move the mouse device (the Hardware) only a bit,
the cursor is speeds from one side to the other.
Also reducing the mouse speed in the Operating System doesn't work.
Everythig else works perfekt (Video, Sound,).
I found no Option in the Configuration that change the speed of the Mouse.
Is there another way to reduce the Speed of the mouse only?
Using 0.74
Already tried mouse sensitivity but movement is not effected.
Reply 1 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
What is your OS? And your mouse? Todays Logitech have a setting for speed in games, copuled with ddraw setting in dosnox.conf should make it adjustable.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 6, by GBlue
Ohm missed to give more Information:
My primary System is Waindows 7 and a Logitech M500 (USB).
But I installed DosBox in i virtual WindowsXP (Vbox). (I use XP for games and testings, that W7 is not messed up with installations and so on)
Oh vergessen.
Mein System ist eigentlich ein Windows 7, die Maus eine Logitech M500 (USB).
Aber ich habe DosBox in einem virtuelen XP installiert.
Das verwende ich imer zum Testen und Spielen um mein System nicht unnötig zu verunreihnigen.
Reply 4 of 6, by leileilol
and if you're paranoid about install programs and registry clutter, don't be. DOS games don't do that, and Dosbox doesn't necessarily require that either.
abstracting DOSBox through a VM will just make your DOSBox experience worse. It runs fine on W7.
Reply 5 of 6, by Dominus
DOSBox Moderator
So, start up Logitechs SetPoint software and play with the mouse settings, especially the advanced ones. But really don't run dosbox in a virtual machine. You CAN but then you need to keep all bug reports to yourself since it is not supported and is probablythe cause of a couple of other problems.
