First post, by GBlue
Hey I've got a Problem with the Mouse in DosBox.
The Mouse is too fast.
First I Thought it was only a problem within the game "Master of Magic".
But iI realized that it is in every game the same.
If I move the mouse device (the Hardware) only a bit,
the cursor is speeds from one side to the other.
Also reducing the mouse speed in the Operating System doesn't work.
Everythig else works perfekt (Video, Sound,).
I found no Option in the Configuration that change the speed of the Mouse.
Is there another way to reduce the Speed of the mouse only?
Using 0.74
Already tried mouse sensitivity but movement is not effected.
