First post, by Jack Barrow
- Newbie
I have seen a lot of programs (fdisk and windows95 😜) that tels dosbox "you must restart or ull see what happen to u" and dosbox do it.
Unfortunatelly shutdown doesent works ("ilegal command", its not implemented i think) so how to send by a .cof .bat a restart?
is there an exe a com that send just that signal? RESTART PLZ
Or how to do one and compile it for DOS.
I know how to do it on C for linux.
also i wrote some asemmbler in C a long time ago to make a space invaders 8086 .But never reboot form it.
Should i learn VB?
Of course i found a really pigy way making a dummy image imgmounting it like 2 or 3 booting from a DOS floppy and calling fdisk to do its magic and at the end it restart. but is so odd. (it works)
thanks in advace
PS: i tried to se in hexeditor the fdisk to se if i found some string or some call. Im not good to reverse engine
