First post, by juliusaugustus
When I try to run Dosbox on Windows 10 it starts but then immediately closes. I tried versions 0.73 and 0.74 and the result is the same, please help!
try a different output in the config
If you are using a tablet, then you will need to plug in a mouse, or use one of these solutions:
"Device not registered" error and exit
http://www.gog.com/forum/general/dosbox_and_w … hscreen_tablets
This should be in the DOSBox forum.
wrote:When I try to run Dosbox on Windows 10 it starts but then immediately closes. I tried versions 0.73 and 0.74 and the result is the same, please help!
Post what device you're running it on and the specs. Also try posting your dosbox.conf in a code block.
World's foremost 486 enjoyer.
Jorpho probably has the right idea. I always forget that Windows 10 + Dosbox - mouse = boom
OK I am using an HP Pro Tablet 608 G1 Intel Atom x5-Z8500 Tablet with 4g Ram, 64gb flash memory with Windows 10 Pro build 14393.321. I tried plugging in a logitech keyboard and touchpad combo and that worked. I also tried SVN build r4000 and I managed to get that work without a keyboard.
*moved to DOSBox General forum*
Please use the DOSBox forums for questions concerning DOSBox
