mscdex buffer
First post, by mmafterme
When I try to play Star Crusader using DOSBox I do the following:
mount c c:\
mount d e:\ -t cdrom
Since the game requires the cdrom to work I obviously had it loaded into DOSBox, but whenever I try to run the game I het the following error:
Exit to error: MSCDEX cannot allocate default buffer.
I have no idea how to fix the problem, and any help would be loved.
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
nope. see if game has a .exe 😀 else hope the next version of dosbox will fix your problem.
Water flows down the stream
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
it's not hard. it's quite simple actually. Just make sure that you put in the exeheader less memory then the comfile would use.
