Help with running a very old game installer
General information and assistance with DOSBox.
Postby rado84 » 2017-11-29 @ 18:25
Hi. I read the readme file of dosbox but the farthest point I got to was mounting the folder where the setup.exe is. I can't find a way to run the setup file and install the game, so that I can play it. It's a very old game called MotoExtreme. Unfortunately it's so old that I can't find the game CD Ripped anywhere.
This is what the game CD looks like:
https://s33.postimg.org/dfo0at56n/WP_20 ... 12_Pro.jpg
And this is how far I got following the instructions:
rado84
Re: Help with running a very old game installer
Postby BeginnerGuy » 2017-11-29 @ 18:37
Just going by your picture, you mount your game folder as the C: but you aren't switching to your C: drive yet
Try as follows:
mount C D:\torrents\motoex
C:
setup.exe
type dir to have it spit out the contents of your current directory so you can see what files it contains, setup.exe for your game is not in the Z: drive in this case, it's in the root of your C drive.
Sup. I like computers. Are you a computer?
User avatar
BeginnerGuy
Postby rado84 » 2017-11-29 @ 18:50
I did what you said (typing C:, then "dir" and it showed the files, the setup.exe included). But when I typed (in C:) setup.exe, a message appeared "this program can not be run in dos mode". Which is weird because me and my best friend used to play this game under DOS when we were kids (21 years ago).
I already tried running the setup under a Windows 95 VirtualBox with no success - the setup.exe just wouldn't run under Windows.
rado84
Postby DosFreak » 2017-11-29 @ 21:04
It's likely a 16bit Windows executable so run it on a 32bit Windows OS.
Also we don't support "abandonware" here.
Closed.
User avatar
DosFreak
Return to DOSBox General
Who is online
Users browsing this forum: JosSchaars and 3 guests
