First post, by Guest
Hi there !
I just found out about DOSBox and hope that I'll be able to use it. But I got some troubles making it run.
When I start DOSBox a small window opens and I receive the message
"Welcome to Darwin!
Bodo-Zentners-Computer:~ bodo$ /Users/bodo/dosbox; exit
dyld: /Users/bodo/dosbox can't open library: /usr/local/lib/libSDL-1.2.0.dylib (No such file or directory, errno = 2)
Trace/BPT trap
logout
[Prozess beendet]"
I have installed the SDL library. I can find it under "Mac Harddrive/library/Frameworks/SDL.framework/SDL".
How can I tell DOSBox where it can find the SDL library ?
I would be cery happy if I would get some help !!
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
uhm use radnor.
and/or make symlink to were dosbox expects sdl to be .
Some googling may do wonders as well. as I've seen this problem on some mac sites as well.
Water flows down the stream
