First post, by himhum
at first i want to say thank you very much for dosbox. it's a really great project. 😁
when i try to set up an ipx-tunnel-server with
# ipxnet startserver
i receive the following error-message:
"IPX Tunneling Server failed to start"
i use dosbox 0.62, linux kernel 2.6.8. my dosbox.conf contains the line "ipx=true". is the ipx over tcp/ip tunnel thing not supported on linux? or am i missing something very obvious (perhaps in my dosbox.conf). thx a lot for your help. 😀
