First post, by himhum
at first i want to say thank you very much for dosbox. it's a really great project. 😁
when i try to set up an ipx-tunnel-server with
# ipxnet startserver
i receive the following error-message:
"IPX Tunneling Server failed to start"
i use dosbox 0.62, linux kernel 2.6.8. my dosbox.conf contains the line "ipx=true". is the ipx over tcp/ip tunnel thing not supported on linux? or am i missing something very obvious (perhaps in my dosbox.conf). thx a lot for your help. 😀
Reply 1 of 4, by canadacow
Could be one of two things:
1) Something is already running on port 213. Try a different port.
2) Your computer can't obtain its IP information for some reason.
Let me know if this helps.
Reply 2 of 4, by himhum
thx, it seems like port 213 didn't work. iirc only root can use ports < 1024 on linux. using a port above 1023 solves this issue. i recommend adding this information to the wiki or networking guide, because it's a really annoying problem. perhaps setting the defaultport to something above 1023 in generell would be a good idea? it wouldn't harm the win-users and the linux-users would appreciate it for sure.
anyway problem solved, z working with ipx over tcp multiplayer in dosbox on linux. *yay!* 😁
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
Is this okay?
http://dosbox.sourceforge.net/wiki/index.php? … dosbox.conf#ipx
_________________
Reply 4 of 4, by himhum
if this entry would have been there earlier this thread probably would not exist. so i guess it's ok. 😀 thx
