Dosbox for macbook
First post, by nieckar44
Hi
since i updated my MacBook to Catalina i can't use it, is there any other way i can use it
Cheers
John
Reply 2 of 34, by nieckar44
thanks mate
i am getting this message
"DOSBoxSVN" can't be opened because apple cannot check it for malicious software
Reply 3 of 34, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Right click on the app and click on "open". Usually this will result in another dialog where you can select "open" again.
Might have to do it twice.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 34, by nieckar44
cheers mate
i think its apple because i am getting this message
you can't open the application "Cmexe.exe" because microsoft Windows applications are not supported on macOS
Reply 6 of 34, by nieckar44
its championship manager and trying to play the game
Reply 8 of 34, by IIGS_User
Probably doing what all the Windows users do to mess their productive system: "Open .exe with DOSBox.exe"
You must run DOSBox, mount the folder containing cm*.exe, then run the application.
Klimawandel.
Reply 9 of 34, by nieckar44
i normally right click Cmexe.exe file the open with dosbox but now i get this message
Reply 10 of 34, by nieckar44
any chance you could give my how to do it please
Reply 11 of 34, by Dominus
DOSBox Moderator
60 seconds guide to getting your game to run in DOSBox <- but you need to adjust that for OS X since the paths are different
Reply 12 of 34, by nieckar44
hi
i been try to sort it but i can't do it i will have to wait until there's a new update for dos box to play my old games 🙁
Reply 14 of 34, by nieckar44
i can't get dos box to work
Reply 15 of 34, by DosFreak
It sounds like you don't know how to use DOSBox. A new version isn't going to help you there.
Post exactly what you are trying to do with screenshots and a detailed explanation for each and mabye someone can help.
Make your games work offline
Reply 16 of 34, by root42
nieckar44 wrote on 2020-05-04, 10:01:
Read the manual.
Otherwise, here is a build of Boxer that I just made, which should hopefully be 64 bit and might run on your machine. To install games, just drag and drop them onto the Boxer window. Should be rather easy...
I have Mojave, so it will also run as 32bit with me, can't test on Catalina.
Link to the build: https://drive.google.com/open?id=1yTNOG4J6Qtg … 3jUnbA_kxkiO2bf
YouTube and Bonus
Reply 18 of 34, by root42
Dominus wrote on 2020-05-04, 13:06:
Right, Boxer is probably the easiest 😉
(I was about to suggest a frontend but this probably works better)
If it works. I could only test on Mojave. Boxer is officially not 64bit compatible I took this fork, which is supposedly 64bit compatible: https://github.com/MaddTheSane/Boxer
YouTube and Bonus
Reply 19 of 34, by nieckar44
i updated my MacBook to Catalina and it won't work it used to work with my last iOS
just tried to down load boxer and it won't let me install it
