Dosbox for macbook
First post, by nieckar44
Hi
since i updated my MacBook to Catalina i can't use it, is there any other way i can use it
Cheers
John
Reply 1 of 34, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
try that https://www.dropbox.com/s/kbrf5elbcu66kst/Dos … apshot.dmg?dl=0
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 34, by Dominus
DOSBox Moderator
Right click on the app and click on "open". Usually this will result in another dialog where you can select "open" again.
Might have to do it twice.
Reply 5 of 34, by Dominus
DOSBox Moderator
Cmexe.exe? What are you doing? How is this happening? A screenshot please!
Reply 7 of 34, by Dominus
DOSBox Moderator
So how are you doing this? Through dosbox you shouldn't get this message
Reply 8 of 34, by IIGS_User
Probably doing what all the Windows users do to mess their productive system: "Open .exe with DOSBox.exe"
You must run DOSBox, mount the folder containing cm*.exe, then run the application.
Klimawandel.
Reply 11 of 34, by Dominus
DOSBox Moderator
60 seconds guide to getting your game to run in DOSBox <- but you need to adjust that for OS X since the paths are different
Reply 15 of 34, by DosFreak
It sounds like you don't know how to use DOSBox. A new version isn't going to help you there.
Post exactly what you are trying to do with screenshots and a detailed explanation for each and mabye someone can help.
Make your games work offline
Reply 16 of 34, by root42
nieckar44 wrote on 2020-05-04, 10:01:
i can't get dos box to work
Read the manual.
Otherwise, here is a build of Boxer that I just made, which should hopefully be 64 bit and might run on your machine. To install games, just drag and drop them onto the Boxer window. Should be rather easy...
I have Mojave, so it will also run as 32bit with me, can't test on Catalina.
Link to the build: https://drive.google.com/open?id=1yTNOG4J6Qtg … 3jUnbA_kxkiO2bf
YouTube and Bonus
Reply 17 of 34, by Dominus
DOSBox Moderator
Right, Boxer is probably the easiest 😉
(I was about to suggest a frontend but this probably works better)
Reply 18 of 34, by root42
Dominus wrote on 2020-05-04, 13:06:
If it works. I could only test on Mojave. Boxer is officially not 64bit compatible I took this fork, which is supposedly 64bit compatible: https://github.com/MaddTheSane/Boxer
YouTube and Bonus
