First post, by Guest
Hello,
I just installed Petit Dosbox on my Macintosh, and although I used the "Browse" button to chose the directory where my DosBox (.63) executable is stored, Petit Dosbox tells me that "dosbox was not found in the specified path".
Am I doing something wrong? Is there a way to fix that problem? Help! 🙁
Reply 2 of 9, by MiniMax
Rank Moderator
Moderator
Maybe you need to point to the DOSBox excutable instead of just the directory?
_________________
Reply 8 of 9, by guest
I get the following error message or similar attempting to run Petit Dosbox Incorporated on two different machines from the Desktop. Does this suggest and installation error or the absence of the Developer Tools?
dyld: /Volumes/Macintosh HD/Users/davidjones/Desktop/pdosbox/Petit dosbox.app/Contents/MacOS/DosBox can't open library: /usr/local/lib/libSDL-1.2.0.dylib (No such file or directory, errno = 2)
