First post, by Guest
Hello,
I just installed Petit Dosbox on my Macintosh, and although I used the "Browse" button to chose the directory where my DosBox (.63) executable is stored, Petit Dosbox tells me that "dosbox was not found in the specified path".
Am I doing something wrong? Is there a way to fix that problem? Help! 🙁
Reply 1 of 9, by c-Row
That was me btw... didn't keep me logged in.
Reply 2 of 9, by MiniMax
Rank Moderator
Moderator
Maybe you need to point to the DOSBox excutable instead of just the directory?
_________________
Reply 3 of 9, by c-Row
The executable itself can not be selected, as he asks for (and only lets me chose) the directory.
Reply 4 of 9, by guilly38
Petit dosbox only works with the Terminal version. Make sure that the version you have does not have ".app" extension.
Reply 5 of 9, by guest
Where does one find the "terminal" version of DosBox for Mac OS-X instead of the ".app" version?
Reply 7 of 9, by guest
Found Petit Dosbox Incorporated via VersionTracker this morning. Thank you for bundling the two together.
Reply 8 of 9, by guest
I get the following error message or similar attempting to run Petit Dosbox Incorporated on two different machines from the Desktop. Does this suggest and installation error or the absence of the Developer Tools?
dyld: /Volumes/Macintosh HD/Users/davidjones/Desktop/pdosbox/Petit dosbox.app/Contents/MacOS/DosBox can't open library: /usr/local/lib/libSDL-1.2.0.dylib (No such file or directory, errno = 2)
Reply 9 of 9, by guilly38
To run DOSBox (not Petit dosbox) you need to have the SDL Library installed in your computer.
