First post, by n1ghttr4p
Sorry to ask without doing a deep-dive myself, been short on time lately, but I was wondering which builds will output games dynamically to their original, unscaled/unfiltered resolution properly? I'm using DOSbox on a Windows XP, P4, 1gb, Geforce 5900XT, YMF744 machine as a supplement for the few games that simply will not run with the DSDMA TSR enabled (DDMA and SBLINK are a no-go for this machine, already been down that road) in DOS. At first I was thinking emulation is a sad fallback for a machine that's supposed to run everything natively on hardware, then I realized how nice it looks through Daum SVN as it outputs to the original resolution with fullresolution=original set, looking very much like the real deal with even pixels and low resolution scanlines.
However, this build doesn't run Turrican properly, running in a vert stretched and massively cropped mode. I tried Dosbox-X, which runs the game correctly, but no matter what I do I can't get it to output to the original res like Daum even with fullresolution=original, surface, d3d, or anything.
Is it possible to fix Dosbox-X like I want it, to fix Turrican in Daum, or are there other reasonably modern builds that'll output to original resolution properly?
Reply 1 of 1, by n1ghttr4p
Nevermind. Doublescan did the trick in Turrican and Daum is still the best way to output to the game's original resolution in XP as far as I can tell.
Also, apologies for using the wrong verbiage topic. I mean outputting the game's original, unstretched/scaled resolution and having the CRT monitor change to it for perfect pixels and scanlines. I realize that CRTs don't have a "native resolution" like LCDs.
