Reply 20 of 32, by Scali
wrote:I hope it's that simple ... but I have the feeling that it won't be since the actual values sent to the frequency registers from the VGM are based off of the input clock. If I ever manage to get a chance, I might try that or something to see what works. Thank you for the suggestion! 😀
It should work, I've done something similar for a converter from ProTracker to MONOTONE, where I had to take the Amiga frequency dividers and convert them into PC speaker PIT dividers. It's the same thing really: they act on a different base frequency. Amiga is ~3.5 MHz, where PIT is ~1.19 MHz.
So just detect whenever a frequency register is written to, and correct the value.
