First post, by DoomWarrior
hi
to make it short, i have warnings 😳 , so i 'fixed' some in cmopl.c
i attached the diff. If this is ok, i will fix the other in ymf262.c too 😀
bye
    fmopl.c.DIFF
    4.76 KiB
    178 downloads
    uni diff file
Reply 3 of 6, by almightyjustin
As I said on SourceForge, the FM code is from the MAME project, so if you have any patches, it's better to submit them directly to MAMEDEV (instructions are at http://mamedev.com/ ) and then get DosBox to re-sync to MAME's new version. That way MAME and all the other projects that use the same code (like AdPlug) can benefit from your changes.
Swim, swim, hungry! Stupid fish.
Reply 5 of 6, by HunterZ
You and Moe probably, and anyone else who makes changes to the MAME-derived OPL emulation code.
I should mention that the current official MAME version of that code is different from the current DOSBox version. I don't know enough about how the OPL code or DOSBox work to be able to determine whether or not it's worth merging the changes into DOSBox (and I definitely don't know how to go about it). Someone more knowledgable may want to look into it, however.
If anyone wants to look at it, the latest stable version of the source is here: http://www.mame.net/downmain.html
Patches to the latest development snapshot are here: http://mamedev.com/source.html
I looked but couldn't find a public CVS archive.
Reply 6 of 6, by almightyjustin
Yeah, unfortunately it looks like there have been some changes on both the DosBox and MAME sides, so it could be tricky to sync up again.
MAMEDEV doesn't use CVS, they send patches to a private mailing list and use the development releases to keep in sync.
