First post, by ydnar28
😵 I have version .72 dosbox, and I have the rare pleasure having a cdrom version of system shock. I know it works because I've gotten the install to put the files on my hard drive. The problem is I am getting an illegal error code
illegal command: : f:\cdrom\cdshock.exe
I did double check that both a cdrom drive mounted, and I HOPE HERE the place where the files I installed from the disk is also mounted.
mount d f:\ -t cdrom -usecd 0 -ioctl
mount c C:\games
It recognizes both spots because it give the directories for each, but I can't get it to load... 'newbie banging head into brink wall to make headache go away'
