Legend has a strange issue: its timing gets thrown off if the timer doesn't have a chance to tick during video mode changes. Real video BIOSes have the same problem if they don't execute enough code with interrupts enabled, or if cycles are too high.
The attached loader program idles after mode changes to simulate BIOS overhead, which also prevents a brief graphical glitch in the 320x480 tweaked mode used for the bouncing blue sphere. The idle loop may be insufficient with more than 8000 cycles, but the demo doesn't need near that much. Run the loader where LEGEND.EXE is located.
The parts before and after the glass spheres are not rendered correctly in DOSBox. The DAC pel mask is used extensively in the effect, which is seldom used in games.
Legend's music in MOD format: Reverie of Truth
