First post, by BackSpace
Hello,
Does Dosbox requires special configuration to correctly rendered these demos ?
Here the report after using DosBox 0.74 and SVN r3697 :
- Demo "Crystal Dream" from Triton (http://pouet.net/prod.php?which=463)
*SoundBlaster emulation failed to initialise, the sound is always "rendered" via the PC speaker.
*In this topic : Help with old 3D demos please... this issue has been resolved but the Sb emulation seems to be broken again.
- Demo "Reve" from Pulse (http://pouet.net/prod.php?which=70)
* reve.exe crash Dosbox
- Demo "Vanility" from Byterapers (http://pouet.net/prod.php?which=55531)
* freeze after the "water effect"
* Youtube version : http://youtu.be/bKPL_jC8Tk8, dosbox freeze at ~2:12
- Demo "The bad, the good and the ugly" from Surprise!Productions (http://pouet.net/prod.php?which=1355)
*The first "plasma" effect is badly rendered and also the "stretch effect" at 2:00 (note : these effects are correct with ykhwong's build and "Draw the display line by line" ticked)
*The winged creature have some bad pixels on the wings
Config : Windows 7 64 bits - original dosbox.conf
Thanks for your hard work.
Greetings.
