First post, by Biotoxic
Hello.. iv tried to mount the game using the varius tips from the readme file but still i can't get past the error message i get when i try to start the game.
Go's something like this Place the alien legacy CD in the cdrom device, if u can't find it press escape-. etc etc... Iv read that some of u that played this game managde to get past this. But how?
I hop some one can give me som tips on what to writte to get it to work..
// Biotoxic
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
And I tried to peer into my crystal ball to see exactly how you mount the CD, but I failed. What do you think we should do about it? Should I get a new crystal ball, or could you post the mount instructions here?
_________________
Reply 3 of 8, by MiniMax
Rank Moderator
Moderator
Try the -ioctl and -label options.
_________________
Reply 5 of 8, by SKARDAVNELNATE
If your CD drive letter is E and you have the disc in it "mount d e:\ -t cdrom" should work.
So, is your CD drive letter E?
Do you have the disc in drive E?
And how did you install the game if it isn't reading from the disc?
Reply 6 of 8, by schlub
I am having the same issue... it installs from CD fine (fully legit version BTW) but I can't get it to work. I've tried using a win98 virtual machine... i'll give DOSBox a go and see how it goes
The actual message is:
"Place the Alien Legacy CD in the CD-ROM drive. If you cannot locate the appropriate CD, type [ESCAPE] to exit to DOS. Otherwise, type any other key to continue."
