Daggerfall install
First post, by AngelOfPain
first i want to say sorry if this has already been explained. this is my problem. i reciently just dled daggerfall from there website and i am new to the whole mounting thing. i have tried to use your instal guide but still cant get it working. i would be thankful for any help.
i want to install the game to my game folder
d:\games
install file is in
d:\check\daggerfall\1\dfcd
my cdrom is e:\
this is what i have tried
mount c d:\check\daggerfall\1\dfcd
mount d "e:\" -t cdrom
followed all instruction (unless i missed something)
next i tried
mount c d:\games
mount d "d:\check\daggerfall\1\dfcd" -t cdrom
that didnt work
plz if you can help i would be ever so greatfull
Reply 4 of 6, by DosFreak
Instructions inside DOSBox would be the same except for the mount points. Outside of DOSBox you need to use whatever extraction program is available on OSX to unzip .zip's.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 6 of 6, by Vince.Bloodworks
Hey AngelOfPain, one of my friends have the same problem.
To install you have to do this:
-mount your DFCD folder as cdrom by type in:
mount e d:\check\daggerfall\1\dfcd\ -t cdrom -ioctl -label Daggerfall
( letter "e" is just an example )
-mount your Folder where you want to install it to
And here maybe occurs a problem! When you try to install daggerfall the setup says that you don't have enough space on your harddisk. To install daggerfall without problems mount your games folder like this:
mount c d:\games\ -freesize 2000
With this you set up your mounted drive "C:" with 2000 Mbyte free diskspace.
Now change to "E" and run the install program.
It should work now. And every time you want to play daggerfall you have to mount DFCD first like above. Make a batch file doing this 😁
Hope this will help you 😉
