First post, by newsdee
Has anybody been able to install TFX (flight simulator from DID) in Dosbox?
I can't even install it under Windows... (crashes saying something about the 16-bit subsystem trying to access the HDD directly)
Don't panic.
Don't panic.
Well dosbox doesn't like the same.
Water flows down the stream
You need to mount directory with installation files as a floppy (with -t floppy), then it will work.
I had the same problem.
Thanks! It's a bit slow to load, but then it works great!
Don't panic.
Hello!
I've got somewhat different problem when trying to run TFX. As I am new to dosbox0.63, i read read me and pictorial guide. Unfortunately i didn't quite understand this solution you posted here cuz it asked me for a floppy and i don't have a game on floppy.
However I mounted my c: and done what is explained. In the TFX folder i have CONFIG.BAT file wich runs normaly, but when i want to run TFX.BAT it says:
c:\games\tfx>tfx.bat
c:\games\tfx>start demo
loading...Hardware change please install again
Same happens when i try to run START.EXE
I tried to find the answer so not to bother ye, but i guess I suck, so sorry in advance.
