First post, by sleepindawg
I just tried getting Railroad Tycoon to run in Dosbox under Windows 10. Everything seems right until I try to lay track, that function doesn't work. Of course, I did try the tutorial which allowed me to build a new engine, so I'm guessing that other things will work if I can get track laying working.
Here's some info that may be useful for advising me, I'm trying to run the game on a Lenovo Ideacentre AIO 700 and as stated above my OS is Windows 10.
Thanks in advance for any help anyone can offer,
the dawg
Reply 4 of 9, by DosFreak
Are you using the numpad?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 6 of 9, by sleepindawg
Yes, but if you are thinking of operator error with the numlock I checked and rechecked it.
BTW, I want to thank you guys for your thoughts on this matter.
Reply 7 of 9, by kolderman
sleepindawg wrote:
kolderman wrote:
I mean in dosbox. Look at cpu/cycles.
It's at 6000. How much should I change it?
Start low (500) just to see if it fixes the problem, then increase if needed to be playable.
Reply 8 of 9, by sleepindawg
No luck, if you have other suggestions please share, also thanks for trying.
EDIT: It just dawned on me that I likely should have mentioned that the cursor moves, but nothing else happens. It's as if I'm not holding the shift key down.
