First post, by blarg
Hi,
I've got Bioforge to run under DosBox 0.63, although it's pretty slow. My problem is I seem to be stuck right at the start of the game. I'm at the part where you're lying down on a bed with some ominous music playing. I think some event is supposed to happen to wake you up, but that never happens. I think it might be some timing trigger that isn't going off.
I'm running an AMD 2.0 GHz machine with 512 MB of RAM. I have frameskip set to 1, and cycles set to 4000. I have tried dynamic and normal core, but I'm not really sure what those affect. Has anyone had a similar problem running the game, and can help?
