First post, by vipul
I am getting error regarding ctempc.bat file (Can't open ctempc.bat file).
As well, there is few linker errors. I am attaching screenshot here.
Thanks in advance!
Reply 1 of 2, by DosFreak
Check that you mounted the directory correctly
Check that your PATH variable is correct if you want to use it.
Check your batch files and verify that the files can be accessed where the batch file expects them to be.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
