First post, by Pierre32
- Member
I'm not getting any sound at all in Sierra's Fun Seeker's Guide to Eastern Madera County.
Note: I am primarily testing in Scali's FB-01 build, but running the same tests in 0.74-3 and the results are the same.
- Selecting Adlib in the game's setup (ADL.DRV) returns an "0x89/3 not found" error on launch (and I've tried all the various SB options in dosbox.conf).
- With PC Speaker (STD.DRV) it runs fine, but is silent.
- I have a real Yamaha FB-01 attached. Using either IMF.DRV or FB01.DRV, I see the MIDI transmit but then the game runs silently.
The problem is unique to this title. If I didn't know better I'd assume it just didn't have sound, but I've seen references to the fact that it does. Any ideas?
