Sound Driver Pack
Reply 40 of 79, by Riikcakirds
Arnie 2 (1993) Celery Software - CT-VOICE.DRV v1.15 (ver hex 0F 01)
Fields of Glory (1993) MicroProse
Monopoly (1993) Supervision Entertainment Ltd.
PC Fútbol (1993) Dinamic Multimedia, S.A.
Whale's Voyage (1993) Flair Software Ltd
Dreadnoughts (1992) Turcan Research Systems Limited
Olimpiadas 92: Atletismo (1992) Topo Soft
Reply 42 of 79, by Riikcakirds
Games using Adlib sound.com
The Cardinal of the Kremlin (1990)(IntraCorp)
Si Chuan (1990)(Soft-World)
Questmaster I- The prism (1989)(Miles Computing)
Majung Academy (1990)(Soft-World International)
NY Warriors (1991)(Arcadia Systems)
Tilt (1991)(Genias)
Balance (1993)(Kingsoft)
Dynatech (1992)(Magic Bytes)
Sea Rogue (1992)(Microplay Software)
Day of the Viper (1990)(Accolade)
Gunboat (1990)(Accolade, Inc.)
Xenocide (1990)(Micro Revelations)
Elysium (1992)(Magic Bytes)
Reply 43 of 79, by Uka
Nice list, Akuma!
I have some more to add:
* Hooray for Henrietta (version 2.0 from 1992) by Lander Software - requires both CT-VOICE.DRV and SBFMDRV.COM.
* Spellbound! (1992) by Lander Software - requires both CT-VOICE.DRV and SBFMDRV.COM.
As far as I remember, the second one needs SB Pro, not just SB1/2.
Reply 44 of 79, by Akuma
Riikcakirds wrote on 2021-03-26, 18:28:
Games using Adlib sound.com […]
Tilt (1991)(Genias)
Another great list 👍 Added and credited
Gunboat was already in there.
Uka wrote on 2021-04-02, 11:38:
Nice list, Akuma! I have some more to add: * Hooray for Henrietta (version 2.0 from 1992) by Lander Software - requires both CT- […]
Nice list, Akuma!
Its you guys that make the list 😁
Added and credited
Reply 45 of 79, by Art
I don't know if it's considered to be a sound driver, but "Sound, Graphics & Aircraft Upgrade" for Microsoft Flight Simulator 4.0 requires SBTALKER.EXE and SBTALK.BAT from the Sound Blaster installation package to be able to speak.
Reply 46 of 79, by Akuma
Art wrote on 2021-05-18, 13:12:
Thought about it:
If it needs soundcard software to run properly, I'm adding it 😁
I'll bet there are more out there 👍
Added and credited
Thanks!
Reply 48 of 79, by keropi
Akuma wrote on 2022-04-08, 08:13:
Updated CT-VOICE section with approximately 100 games
these are many games...!
so what's next , a CT-VOICE.DRV for generic cards? 😁
🎵 🎧 PCMIDI MPU , Orpheus , Action Rewind , Megacard and MK8330 soundcard website
Reply 49 of 79, by Akuma
keropi wrote on 2022-04-08, 09:57:
Nope, AdLib games 😁, added 18 games to the AdLib SOUND.COM list.
Found a hacked AdLib SOUND.COM 1.31, but its too messed up to add 🙁 *bummer*
Edit:
added 84 games to the SBFMDRV.COM list, yay!
Reply 52 of 79, by Akuma
badflame wrote on 2022-04-10, 19:00:
Hi, […]
Hi,
add to the list "Fiendish Freddy's Big Top O' Fun".
Needs sound.com driver to run game using -ADLIB parameter with .exe
Greetings.
Yay!, added and credited under SOUND.COM
llm wrote on 2022-04-11, 05:45:
your README.MD in the 7z file is not up to date 🙁
Thanks, I will update those lists when I have something substantial to add for pack 1.03
Reply 53 of 79, by llm
is the latest version of such a driver always the best for dosbox or are there games that need specific versions?
im thinking about reversing some of the drivers and looking for the right versions when used with dosbox
Reply 54 of 79, by Gmlb256
Hello Akuma.
The SBFMDRV version 1.30 is dated July 17 of 1991 and that file can be gotten from the following collection of Creative driver and floppy disk images here: http://vogonsdrivers.com/getfile.php?fileid=6
It is inside a LHA compressed file called DRIVER.LZH located at SOUNDBLASTER DRIVERS\SoundBlaster Pro CT-1330A Install Disks\SoundBlaster Pro I\SBPRO DISK1\
There is also a different version of CT-VOICE.DRV (5,014 bytes, dated October 31 of 1991) which isn't in the Sound Driver Pack.
Reply 55 of 79, by llm
Gmlb256 wrote on 2022-05-04, 02:46:
there is already a 1.30 on the list - whats the point?
i can't find the SOUNDBLASTER DRIVERS\SoundBlaster Pro CT-1330A Install Disks in the vogonsdrivers, there is no SOUNDBLASTER DRIVERS under the Sound Devices - direct link?
Reply 56 of 79, by Gmlb256
llm wrote on 2022-05-04, 04:57:
The one that is on Akuma's driver pack doesn't have the actual timestamp.
i can't find the SOUNDBLASTER DRIVERS\SoundBlaster Pro CT-1330A Install Disks in the vogonsdrivers, direct link?
I should have told that properly.
The entire path is inside the compressed file called SOUNDBLASTER_DRIVERS.RAR which has to be downloaded from the link that I provided.
Reply 57 of 79, by llm
Gmlb256 wrote on 2022-05-04, 05:02:
its version 1.34 - the french version
found it, there are also some SBTALKER.EXEs in the archives - sadly my 7zip can show me the content of the LZHs but not uncompress, but maybe Akuma got the right tools
Reply 58 of 79, by Gmlb256
llm wrote on 2022-05-04, 05:16:
Was talking about the one was incorrectly dated December 8 of 2020 and has the empty folder UNKNOWN_TIMESTAMP along with it.
Yep, it cannot be extracted with 7-zip. It would require using the DOS LHA extractor or a different software capable of doing this.
If using the DOS application, don't use vanilla DOSBox as it will set the incorrect timestamp. Use DOSBox-X or a real machine for this.
Reply 59 of 79, by Akuma
llm wrote on 2022-05-01, 09:10:
IF it works, yes, but there lays the problem, I always start with SB1.0 and work my way up.
Hello Akuma. […]
Hello Akuma.
Thanks, I'll check it out and add it to the pack.
