Shouker wrote:Hi
I run windows 95B under dosbox 0.74
With machine=svga_s3 the display of icons is completely messed up for 256 colors, 16 bits and 32 bits colors.
I tried somes other s3 drivers but I didn't found something working properly
It is working for someone with svga_s3 ?
dada wrote:TODO
- Get internet working
- Get CD-ROM drive working (is this possible?)
- Find out how to easily move win95 dir to disk image on Windows host operating system
dada wrote:My install was entirely done on core=normal. Actually, I installed it on core=simple before, which worked too until I reached Windows proper at which point it resulted in massive visual glitches. It should be working. Are you sure your Windows ISO is not damaged somehow?
h-a-l-9000 wrote:Only the first Win95 version runs more or less okay.
Is it the 95B/98 shell that causes the problem? (If it's installing but Explorer is crashing, it's a possibility, right?) It is a fairly straightforward matter to replace it with the shell from the first version of Win95 (either by using 98lite or by manually replacing a couple of files).h-a-l-9000 wrote:Only the first Win95 version runs more or less okay.
Indeed. I have the impression that Mr. Gadget2006 is seeking to run it on other platforms, however.XP1 wrote:This looks like a nice time-killer for Windows 95 lovers. However, wouldn't Windows 95 be more useful and functional if you used an actual OS virtualization software?
