Reply 1960 of 2446, by Wengier
Muz: Why not just use the following commands in DOSBox-X?
IMGMOUNT A 622c.imgIMGMOUNT C windows95.imgIMGMOUNT D longbow.isoBOOT C:
Everything else is not needed (you do not need to specify things like "-size 512,63,16,3072 -t hdd -fs none" or "-t iso -fs iso" in DOSBox-X). And instead of using "IMGMOUNT 3 ...", just use "IMGMOUNT D ...". Moreover, you can find the Windows 95 guide for DOSBox-X here.
