First post, by clueless1
So in the process of trying to gather results from 486 and faster systems with caches disabled, I've been playing a lot with gerwin's Setmul utility.
What a neat tool! I finally took the time to dive a little deeper in the documentation (just reading setmul /? gives a world of info) and realized that there are a ton of switches available to Pentium owners. So I decided to try to test every combination of switches I could with my Pentium Overdrive 200. 😉
36.93 KiB
Even on a Pentium, there is way more to this utility than just disabling L1 cache. I was able to get down almost to an Am386SX40; I equaled an Am386DX40; and I got close to an i486SX25.
Not to mention all the other features for owners of many other types of processors. Thank you, gerwin!
Reply 1 of 27, by PhilsComputerLab
Nice!
I'll have to check that out. Does this also work with the standard Pentium and MMX?
YouTube, Facebook, Website
Reply 2 of 27, by clueless1
I've only tried with the POD so far, but I don't see why not.
From setmul docs:
-Pentium P54C test register "TR12" options. Parameters: BPD - Disable Branch Prediction VPD - Disable V Pipeline L1DX - Disable […]
L1DX - Disable L1 cache exclusively
CCD - Disable L1 code cache
DCD - Disable L1 data cache
PFE - Pentium Features Enable; Resets the above TR12 options to default.
Reply 3 of 27, by gerwin
Nice to see these Pentium options of SetMul put to good use!
Originally I tested it on a Gold-Capped Pentium 90MHz (P54C): All worked fine. After that I also tried it with one of my Pentium MMX processors, 200 or 233MHz (P55C): The TR12 switches no longer had any effect, as if intel removed these registers... So I am surprised to see it work on the POD 200. POD 200 being an MMX model AFAIK.
Edit: correction - The TR12 settings actually do slow down all six different Pentium MMX processors I have here. i just tested that properly. So AFAIK it just works with any Socket 7 Pentium.
Reply 4 of 27, by ibm5155
I wish I could disable the motherboard cache by software 🙁 (even if the restart is kinda fast)
one question, If I set setmul for 500MHz on ms-dos (400 original), and I restart and boot into Windows xp, it's goint to stay at 500MHz or 400MHz?
Reply 5 of 27, by clueless1
Setmul commands only live during the session they are started, so they would not survive a reboot. I believe the docs say it is not compatible with XP (among other more modern OSes).
Reply 6 of 27, by PhilsComputerLab
A real shame it doesn't work on the MMX. That CPU is just a little bit too fast without caches and could benefit from some further slowing down 🙁
Reply 7 of 27, by clueless1
I feel pretty lucky then that it works on my Pentium Overdrive MMX.
Reply 8 of 27, by gerwin
Guess the situation is that somewhere along the production of the Pentium MMX they dropped the Test Registers, and it may be interesting to try out some older MMX models to see if they still support the Test Registers.
Reply 9 of 27, by clueless1
Your P90 is a bit faster than mine (8.97) with L1D. If not too much trouble, would you mind adding your results to my compilation?
https://docs.google.com/spreadsheets/d/1fBPxW … #gid=1443406194
Thanks.
Reply 10 of 27, by PhilsComputerLab
Just a tip, between motherboards, memory configurations and BIOS settings there can be quite some variation.
For example I used 16 MB memory (SDRAM) for better compatibility, but that memory was actually EDO and it slowed things down a bit. Memory timings in the BIOS can also have an impact.
So I wouldn't worry too much about a spread in results using the same CPU.
Reply 11 of 27, by clueless1
Thanks, Phil. I think it's cool that different platforms can show different characteristics. It says something about the ALI Aladdin V and SDRAM.
Reply 12 of 27, by PhilsComputerLab
Yup.
Your thread brings back good memories.
I looked up some old posts of mine from 2010 when I did my own cache experiments and benchmarks. I actually started off with a Slot 1 system, but quickly found that socket 7 is the way to go.
Reply 13 of 27, by clueless1
You definitely paved the way for my inspiration. 😀 Thank you!
Reply 14 of 27, by clueless1
Here are all the combinations of setmul switches and how they effect performance on my POD 200MMX:
29.46 KiB
Reply 15 of 27, by Tetrium
I'm wondering a bit here, but could such a program possibly be able to enable the motherboard cache in a s7 rig which is running a Tillamook?
My retro rigs (old topic)
Report spammers here!
Reply 16 of 27, by clueless1
Sadly, in retesting my Pentium 120 cpu with the test registers, I found DCD and CCD (data and code cache) have no effect. These two switches are what allow my POD 200MMX to get into 486 levels of performance. VPD and BPD do work, which allow smaller performance drops into P90 and P100 ranges, and disabling L1 gets me down to Am386SX-40. I'm pretty stoked that the POD supports all these TRs, it makes it a very flexible CPU, from 386DX-25->386DX-33->486-16->486-20->486-25->P120->P133->P166->P200.
Reply 17 of 27, by Tetrium
This might actually be an interesting find. Better go start hoarding those 200MHz MMX Overdrives real quick before this gets verified by the masses 😜.
Reply 19 of 27, by BreakPoint
How on earth P200 may degradate to 386-25???
I wonder if 386-25 system from your test have L2 cache or not.
My CPU collection - Looking for hardware in Ukraine - Ukraine vintage PC forum
