Bondi wrote on 2021-12-08, 05:00:
Rawit wrote on 2021-12-07, 15:36:
Does this card and the drivers allow you to work with protected mode games?
Nope, real mode games only.
The screenshots and executables seem to hint on protected mode being supported with this version (4.😎 and it's newer than the version shown in the LGR video (1.1 AFAIK).
From https://forums.bannister.org/ubbthreads.php?u … at&Number=85463
"PROT is a small memory resident program (TSR) that holds all of the Protected Mode functions that enable the Action Replay to work with Protected Mode games, such as DOOM, UFO, Theme Park etc. If this program is not loaded then the Action Replay can only be run in Real Mode (normal 640K DOS operation)."
