First post, by Grayshazzle
Hey everyone, I made another new post just to document my status, I figured out how to get power LED working from the keylock header from the first 3 pins. Now I just need to get the HDD LED working, I got a a 5mm LED kit online that is tested and works with my other machines so I put a blue one at the end of the HDD LED cable. I tested the wire itself with a multimeter and that wire is fine as well (also took just the LED and did every connection combo on the HDD with no light coming up). There are 4 pins on the HDD header but is this even meant for LED?
Also, do I need a HDD plugged into the motherboard to truly test if this light works or can it work without a HDD plugged in? I have yet to find a pinout picture for this kind of header as well. If this does not work then it's totally fine as I have a built in LED on my HDD hot swap bay. Just wanted to see if I could get the HDD case light working for giggles. Cheers everyone and thank you all so far for helping me 😀
