First post, by Grayshazzle
Hey everyone, I made another new post just to document my status, I figured out how to get power LED working from the keylock header from the first 3 pins. Now I just need to get the HDD LED working, I got a a 5mm LED kit online that is tested and works with my other machines so I put a blue one at the end of the HDD LED cable. I tested the wire itself with a multimeter and that wire is fine as well (also took just the LED and did every connection combo on the HDD with no light coming up). There are 4 pins on the HDD header but is this even meant for LED?
Also, do I need a HDD plugged into the motherboard to truly test if this light works or can it work without a HDD plugged in? I have yet to find a pinout picture for this kind of header as well. If this does not work then it's totally fine as I have a built in LED on my HDD hot swap bay. Just wanted to see if I could get the HDD case light working for giggles. Cheers everyone and thank you all so far for helping me 😀
    1.96 MiB
Reply 1 of 6, by Repo Man11
The hard drive LED in every setup I've seen uses two pins, so my guess would be the first two pins with pin one being the hot one (maybe the other two pins are for a power LED and are unmarked?). As far as I can recall, I've never seen a motherboard that lights up the HDD LED even for a moment if there is no hard drive activity, so yes, you do need a hard drive connected to one of the IDE ports for the LED to light up.
Reply 2 of 6, by Grayshazzle
Repo Man11 wrote on 2022-02-03, 00:48:
Awesome thank you!
Reply 3 of 6, by Doornkaat
While I think Repo Man11's explanation is more likely it's also possible this board has drive activity indication for each IDE channel. (i.e. the header takes two separate two pin LEDs.) I have had boards like this before.
Reply 4 of 6, by PC Hoarder Patrol
Grayshazzle wrote on 2022-02-03, 01:09:
Awesome thank you!
Think this pretty much covers this and your other thread - Help Figuring Out Motherboard Manual
The manual is Chinese / English but the diagrams are clear enough - found it here https://www.elhvb.com/mboards/pine/manuals/list.html
PM-V01.pdf
2.07 MiB
33 downloads
Reply 5 of 6, by Repo Man11
Doornkaat wrote on 2022-02-03, 08:00:
I've never seen a board that had that, but that's exactly the case here. I guess that means there were computer cases that had two hard drive LEDs?
