First post, by magicmanred
Hello all!
As the Subject says, for some reason when my K6 III+ chip is at 600Mhz (reported correctly in Dos & Win98SE) it only shows 300Mhz max in Win2kPro (NTFS).
If I clock it at 500, Win2k would show 250 max.
If @ 450, Win2k Shows 225.
So on and so forth...
I'm currently using System Commander 8 to have all of these OS's installed on one machine/HDD.
Computer specs:
Gigabyte GA-5AX with F4 BIOS (Super Socket 7)
AMD K6 III+ @ 633Mhz (115 x 5.5)
256mb PC133 CL2 (1 stick)
Voodoo3 3500 AGP
AWE64 Gold ISA
3Com PCI 10/100 NIC
USR 56k ISA
Adaptec 2940W SCSI PCI
Epson SD800 Dual Floppy
ZIP 100 IDE
JAZ 2GB SCSI
Plextor 716A IDE
Pioneer DVD U03S SCSI
Maxtor 80GB IDE
Win2k has SP4.
Is there some hotfix that I need to apply?
