First post, by magicmanred
Hello all!
As the Subject says, for some reason when my K6 III+ chip is at 600Mhz (reported correctly in Dos & Win98SE) it only shows 300Mhz max in Win2kPro (NTFS).
If I clock it at 500, Win2k would show 250 max.
If @ 450, Win2k Shows 225.
So on and so forth...
I'm currently using System Commander 8 to have all of these OS's installed on one machine/HDD.
Computer specs:
Gigabyte GA-5AX with F4 BIOS (Super Socket 7)
AMD K6 III+ @ 633Mhz (115 x 5.5)
256mb PC133 CL2 (1 stick)
Voodoo3 3500 AGP
AWE64 Gold ISA
3Com PCI 10/100 NIC
USR 56k ISA
Adaptec 2940W SCSI PCI
Epson SD800 Dual Floppy
ZIP 100 IDE
JAZ 2GB SCSI
Plextor 716A IDE
Pioneer DVD U03S SCSI
Maxtor 80GB IDE
Win2k has SP4.
Is there some hotfix that I need to apply?
Reply 1 of 22, by chiveicrook
It's quite possible that Win2000 properly uses AMD's PowerNow! dynamic core frequency control. Did you try checking frequency of the cpu under heavy load?
Reply 2 of 22, by magicmanred
chiveicrook wrote on 2022-06-02, 06:53:
That's a good point.
I have noticed that at times the frequency reads 0Mhz, then jumps to half (300 if my cpu is set to 600)
However, I have done full load testing and benchmarks... but the CPU only hits half of the Mhz. And the benchmarks reflect that by having half of the score from Win98. (Sandra 99)
Is there anything in the BIOS that I can tweak to change that behavior? Or maybe it's some Windows update /hotfix /patch that I'm missing?
Reply 3 of 22, by magicmanred
To add...
I've also downloaded and installed SP5.1 for Win2kPro.
No change (other than slowing my windows load time 🤣)
Reply 5 of 22, by DosFreak
See if this works: AMD Powernow v3.04 (I'd be suprised if there isn't a BIOS option to disable it) https://www.driverguide.com/driver/detail.php … driverid=230832
Also check to see what Windows reports your FSB as.
For Intel you'd need Intel Speedstep
Whatever works post in the vogonsdrivers thread to get it added if it's not already there.
Make your games work offline
Reply 6 of 22, by magicmanred
Rikintosh wrote on 2022-06-02, 20:36:
When I installed a Pentium 4 M (mobile) on a desktop I got exactly this problem. Can you tell me the exact model of this K6 III?
I have 3 different CPU's at my disposal that have the same behavior:
AMD K6 2 350Mhz
AMD K6 2+ 570Mhz
AMD K6 3+ 550Mhz
the "K6 2 350" shows as 175Mhz in Win2k
the "K6 2+ 570" I run at 600, so that shows as 300Mhz in Win2k
the "K6 3+ 550" I run at 633, so that shows 316Mhz in Win2k
Reply 7 of 22, by BinaryDemon
If you benchmark it - does it score like a 600mhz cpu or 300mhz cpu?
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 9 of 22, by Jasin Natael
I don't suppose you have tried booting any other OS, Dos or Windows or live Linux to see if the same problem?
Reply 10 of 22, by magicmanred
DosFreak wrote on 2022-06-02, 20:46:
See if this works: AMD Powernow v3.04 (I'd be suprised if there isn't a BIOS option to disable it) https://www.driverguide.com/d […]
FSB is reporting half.
When I have it at 100fsb, win2k repots 50fsb
BinaryDemon wrote on 2022-06-02, 21:10:
Its score is exactly half of that that I get when I boot in Win98 with the same Sandra99 CPU benchmark
Sphere478 wrote on 2022-06-02, 21:29:
What does cpu-z say?
CPU Z shows 300Mhz & 50fsb when Win98's CPU Z shows 600Mhz & 100fsb
Jasin Natael wrote on 2022-06-02, 21:35:
Yes, I have multiple OS's on this system with System Commander.
Dos 6.22, Win 3.11, Win95, Win98, WinME, Win2kPro
Win98 seems to run best.
Win95 doesn't like it when my Mhz is higher than 300 (I get Protection Errors) and when I install the patch, it doesn't seem to work.
Dos 6.22 & Win3.11 work like a charm.
WinME is fine.
Win2k runs very slowly because of the halved FSB 🙁
Reply 11 of 22, by debs3759
OP did say it reported correctly on DOS and 98SE
Reply 12 of 22, by BinaryDemon
“ Just came back to say i sorted it out (APM rather than ACPI.) “
https://arstechnica.com/civis//viewtopic.php?f=17&t=772255
Sounds like this guy had the same issue, maybe reinstall with ACPI disabled?
Reply 13 of 22, by magicmanred
BinaryDemon wrote on 2022-06-02, 22:53:
Interesting! That does indeed sound like the same exact issue.
I guess I have some tinkering to do.
Thankfully I am not hesitant at all to reinstall Win2k. I never really loaded it up once I realized the Mhz issue.
I'll report back with how it responds to these methods.
Reply 14 of 22, by Jasin Natael
debs3759 wrote on 2022-06-02, 22:46:
Yes OP did (in the very first post)
My bad, don't know how I missed that....
Reply 15 of 22, by DosFreak
It's been awhile since I've done it but I want to say a reinstall isn't necessary, think either switching it out in device manager and/or copying over some files will do it.
Reply 16 of 22, by magicmanred
DosFreak wrote on 2022-06-03, 16:41:
Oh really?
This is great news since I hadn't had the time to do the OS Reinstall.
What kind of search terms would you suggest I try to find information on this?
LMK!
Cheers!
Reply 17 of 22, by Socket3
Same here. It turned out the motherboard did not support SpeedStep so the CPU would run at 1200MHz. I installed the same CPU in an Abit IC7 and it worked correctly.
Reply 18 of 22, by magicmanred
Socket3 wrote on 2022-06-04, 08:00:
According to this guy, he solved the issue.
I haven't attempted it yet. The conversation is a little unclear to be honest.
What is described here doesn't make sense with the settings I have in my bios.
Reply 19 of 22, by weedeewee
magimanred, during install of windows 2000 you can press F5, at some point... I don't think it's indicated... might be when the press F6 for driver disk is displayed..., which will allow you to select a different HAL, Hardware Abstraction Layer, to be used for your w2k install. Try selecting Standard PC, or MPS uniprocessor PC, anything aside from ACPI or Advanced Configuration and Power Interface.
heck, it's the same as the last message in that arstechnica link you posted.
Do not ask Why !
