First post, by .legaCy
Sadly both my Athlon XP builds are now without power supply, the last one that i had i tried to recap and check the passive components on the low voltage part, but it's still not functional.
So i need a power supply with a strong enough 5V, i have a Athlon XP 2800+(AXDA2800DKV4D), for a bare minimum i think i need a PSU rated for 15A on its 5V rail.
My go to brand is Corsair, but apparently they don't like to put each rail rated power.
Reply 1 of 13, by aureal
I'm on the hunt for a new psu that can do Athlon XPs too. There used to be a modernish Corsair psu model starting with V something but it got discontinued. I saw some unbranded ones on fleabay stating a high 5V rail but their quality could be anything.
Reply 2 of 13, by waterbeesje
There still are some new ones available with 30A on the+5v rail that keep in spec with little 12v usage. I think you could look at the 700W and higher PSU, just to get these amps.
Stuck at 10MHz...
Reply 3 of 13, by Repo Man11
I use one of these with my 8KRA2+:
Reply 4 of 13, by Repo Man11
Here's another that should work.
Reply 5 of 13, by timsdf
Could try to look locally cheap old OEM units like FSP 250 - 350w. 5V rail on those usually has 22-28A.
Reply 6 of 13, by smtkr
My Supernova 850 has the attached specs
file.php?mode=view&id=142522
Reply 7 of 13, by The Serpent Rider
Max output is a bit low.
Reply 8 of 13, by BitWrangler
The CPU tells us nothing about what PSU you want, the motherboard does. Reason being, late socket A straddled the line between 5V boards and 12V boards. Nforce2 boards often used 12V.
Reply 9 of 13, by The Serpent Rider
To be fair, for +5V system, you can pick PSU with rather anemic specs, but you must be certain that it has OCP protection for that rail set above 150%.
Reply 10 of 13, by pentiumspeed
The Serpent Rider wrote on 2022-08-02, 02:59:
Correct, even 25A of high quality PSU can do 125W and 30A can do 150W.
Question is how much 5V OCP is set on Seasonic PSUs?
Cheers,
Great Northern aka Canada.
Reply 11 of 13, by The Serpent Rider
Depends. Previously Seasonic had rather strict OCP.
Reply 12 of 13, by acl
To avoid having to store 10+ cases, i have a bunch of "fixed" configs, plus a test bench where i assemble the other configs when i want to use one.
On this bench, i'm using the same PSU for everything from Socket 7 to S1366 : SilverStone SST-ST1000G https://www.pccasegear.com/products/16483/sil … 0w-gold-st1000g
I bought it 2nd hand for ~45/50€ (but with one missing cable i think)
I never had issues with my AthlonXP3200+/MSI K7N2 (but i don't know if +5/25A is enough at full load)
Reply 13 of 13, by Repo Man11
acl wrote on 2022-08-03, 12:56:
To avoid having to store 10+ cases, i have a bunch of "fixed" configs, plus a test bench where i assemble the other configs when […]
Like many of the tail end Socket 462 motherboards, the K7N2 has a P4 connector, so a strong +5 isn't important in the way it is with the Socket 462 boards that don't have the P4.
