Reply 46660 of 57998, by Roman555
L-Link wrote on 2022-10-14, 03:27:
Roman555 wrote on 2019-01-25, 15:59:
cyclone3d wrote:
Behold, the QX9750: Somehow I don't think the BIOS is reading the operating speed correctly. It looks to be reading ~1333 x 9.5 […]
Behold, the QX9750:
Somehow I don't think the BIOS is reading the operating speed correctly. It looks to be reading ~1333 x 9.5 instead of 333 x 9.5 ... weird.
I was actually quite surprised to see the BIOS recognize the CPU model correctly since it was never even released and the only samples were supposedly given to people working at Intel. I've only been able to dig up a few mentions of this CPU.
Lot's of misinformation about it floating around unless there were different versions of it. Unlike the QX9770, it runs at 1333fsb instead of 1600fsb.
The BIOS (1.60) is too old. And it doesn't support 45nm s775 CPUs. I have the similar issue with Wolfdale Pentium E5x00 on Asrock 775i945gz. Moreover CPU-Z shows that the CPU works only at 1200MHz in Windows 7. What about yours? Have you tested it in Windows yet?
I asked the manufacture support to send me beta bios they have for sure but there's no answer yet.
Hi Roman
I haven't check it yet, but I think this is the BIOS you were looking for.
Thank you L-Link!
Grabbed it into my collection though I don't have this model since that. I had to slightly modify the stock bios myself to add 45nm support. But yours would be definitely better.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 46661 of 57998, by BitWrangler
BitWrangler wrote on 2022-10-14, 02:02:
a couple of 500GB cheetah SATA drives,
So much for the theory about posting wrong technical stuff on t3h interwebs and having a thousand ppl correct you.... So I was hunting up info and cheetahs are SCSI drives aren't they??? (Pic of item on site is generic pic I think)
Reply 46662 of 57998, by TrashPanda
BitWrangler wrote on 2022-10-14, 15:07:
Might be SAS versions too.
Reply 46663 of 57998, by totoro
Bought this broken Compaq Armada 7770DT laptop from local recycling center. It is in a sorry state, the screen is broken, the plastics also broke in various places, the hinges are stiff, delete key cap aso broken, hard drive missing due to data security laws most likely. But it seems to work at least. Looks like some Pentium MMX and has 64Megs of EDO RAM. Since it has all the ports in the back, it might just become a sort of Comodore/Amiga style PC 😄
The attachment Broken-2022-10-15-120824_002.jpeg is no longer available
The attachment cracked-2022-10-15-103552_002.jpeg is no longer available
Penguin Workshop
https://viekelis.lt
Reply 46664 of 57998, by PcBytes
If the LVDS connector is anything like my Armada E500 (a small 20-ish or so pins) and the CCFL inverter isn't something funky, you could replace the screen. My Armada E500 had suffered nasty and horrifyingly stinky burn marks from sitting over the span of a year (and in a dark place no less, so no sunlight involved), and I managed to find a new display for it (although ever so slightly bigger that it won't screw in on the old hinges) that had the same LVDS connector.
Reply 46665 of 57998, by totoro
Yes, that might be done, but I'll have to open it first and check what kind of screen it has. It's not that easy to find replacements for laptops this old, but of course, possible. The hinges also feel way to tight and the whole thing might just fall apart due to cracks... So yeah, will see.
Penguin Workshop
https://viekelis.lt
Reply 46666 of 57998, by mpe
Some new toys:
Uncommon late VLB VGA with Alliance Promotion chipset:
Yet another fine VLB card (#9 GXE):
And also Shuttle HOT-539 motherboard which is not only one of the very few Pentium motherboards with UMC 8890AF chipset, the one that can take 2MB of L2 cache, but also the exact model I was running as a teenager back in 90s. I was so lucky to have Pentium 75 in 1995.
Blog|NexGen 586|S4
Reply 46667 of 57998, by gmaverick2k
promise ultra100 tx2
Intel pro 1000 gt pci
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 46668 of 57998, by OMORES
This fake Intel SL283 (supposedly a Pentium 233MMX) with a Zida TX98-3D motherboard.
Be kind, rewind... to YouTube
Reply 46669 of 57998, by RaiderOfLostVoodoo
OMORES wrote on 2022-10-16, 10:06:
So this is a MMX 166 which has been overclocked to 233?
Reply 46670 of 57998, by TrashPanda
Quick question, Anyone have a good suggestion for a GeForce 4 Ti equivalent in PCI ? (Needs shaders)
I Have a FX5500 and a X1300 both in PCI but neither feels right for a dual Tualatin board. (Board doesn’t have AGP or PCI-X)
The X1300 might be closest in power to a Ti card and the 5500 is uhh pretty terrible.
Reply 46671 of 57998, by BitWrangler
What stops the X1300 feeling right? Because you just have to go later to get faster, which means XP only. 9400GT is alright for a PCI card, as long as you are expecting 7600 performance out of it, not 9600GT. There is one "good" radeon 9200 with 128bit RAM, which might be said to be equiv to a 4200ti in some stuff. If you are wanting 4600 juice though, it's upwards of that... if you want downward compatibility, then it's that FX5500 and slower.
edit: holy crap, seems later cards that you can actually verify have regular PCI are over a hundred bucks now. Lots of PCIe and AGP miscategorised though, but hopefully that means you'll catch someone listing at their prices rather than the crazy prices.
Reply 46672 of 57998, by PcBytes
Two more scores for today - another (!!) GForce 4 Ti4200 128MB (not sure but might be a Dell OEM card?) and a Sound Blaster Audigy SB0090.
file.php?mode=view&id=147740
The only issues found was three missing caps on the backside of the GF4 Ti 4200, which I managed to solder back with caps scavenged from a dead MXM-format 9600M GT.
Reply 46673 of 57998, by OMORES
RaiderOfLostVoodoo wrote on 2022-10-16, 11:31:
Sort of... Most repainted Pentium CPUs were not MMX.
Anyways the board works and it's jumperless, I can set the CPU to 233Mhz, but I guess it's not stable.
Reply 46674 of 57998, by TrashPanda
BitWrangler wrote on 2022-10-16, 14:03:
Yup, prices for pci cards are crazy.
Wanted a GT430 PCI but not at 200 USD 🤣.
Reply 46675 of 57998, by Jed118
There's a new Value Village at my end of the city, so I got 2 90s amplified speakers, a serial mouse, and a 17 inch monitor. I wish they'd supply the whole computer that mouse came with...
What's for sale? my eBay!
Reply 46677 of 57998, by EvieSigma
Jed118 wrote on 2022-10-16, 15:23:
Relatable, I found a Micron branded keyboard the other day at the thrift store but I'd much rather find the computer...I've been looking for a Micron Pentium MMX tower for a couple years and I keep coming up empty handed.
Reply 46678 of 57998, by Demetrio
For a Pentium II build I'm doing.
Waiting for the other components to arrive.
Reply 46679 of 57998, by libby
Oh hey Jed. 😉
