Reply 46740 of 56770, by RaiderOfLostVoodoo
TrashPanda wrote on 2022-10-19, 16:55:
The PCI Et4000 is based on the VLB version and there is very little performance difference between them, if you have the vlb version then that’s as good as it gets for that bus without getting expensive.
What would be better than an ET4000 on VLB? :>
I found the ET4000 in a literal junk pile and saved it from the scrappers. The card that grabbed my attention was a Voodoo, but I also spotted ET4000, ET3000 and an Adaptec SCSI controller for ISA. When the parcel arrived I also found a valuable Apple card and a super rare emulator card, which didn't even debut on Youtube yet. Best pile of junk ever. xD
Couldn't test the ET4000 yet, because I don't had a VLB board. So it's nice to have a board now. Definitely gonna keep it, so I can test other VLB cards I might find in junk piles.
Reply 46742 of 56770, by bjwil1991
I paid $49.15 $44.65 after taxes and S&H.
Reply 46743 of 56770, by berenyi_kft
Just got this from ebay 😀
Box has seen better days but it includes the driver CD and for £26 I can hardly complain 😁
Motherboard: ASRock 775i65G rev 3.0
CPU: Intel Pentium Dual Core E5800 3.2GHZ
RAM: Corsair CMX1024-3200C2PRO DDR 400MHz CL2 1GB x 2
GPU: Sapphire ATI Radeon HD 3850 AGP
Sound: Audigy 2 ZS
CRT: Iiyama Vision Master Pro 454 HM903DT 19'' 1920x1440 85Hz
Reply 46744 of 56770, by BitWrangler
Heh, must be the bridge chip that creates all the heat for that cooler being needed, my PCIe version is single slot with a much smaller one.
Reply 46745 of 56770, by Thermalwrong
Radical Vision wrote on 2022-10-19, 10:58:
Got this SeaGate (not Barracuda or Medalist) 200MB, for cheap it works fine, no bad sectors..
That's a great old drive 😀 I have a fondness for this era of hard drive since our first 486 PC housed in an XT case had a very similar drive. The anti vibration mounting and the front LED connector disappeared on all later generation drives. This era of drive and the MFM drives like the HardCard are my favourite harddrive sounds.
Always worth saving one of these especially old drives, where the rubber dissolving hasn't killed the drive.
I've got two of those Seagate ~250mb drives, one works perfectly and the other stops working after a minute or two of operation even after trying to change capacitors and stuff. Most other desktop drives from this era that I've had, did not survive old age. I've got a few older drives in the sub 1GB capacity range, especially for laptops, but quite a few of them the rubber noise damper dissolving has made them so that they only start when I give them a hard knock to free up the arm, which kinda ruins the drives after not very long.
I got this Compaq Armada 7350MT for cheap as untested and it's a real fixer upper, I bought it mostly for the fact that I know it contains an ESS wavetable. But it's a mass of broken plastic so far I've had to rebuild one of the weak points with superglue and baking soda.
The attachment 7350MT.jpg is no longer available
I did not realise just how hard it was to get a suitable caddy for this laptop though. No way I can find one for sale but huh, I happen to have the connector that fits it from my spare parts 'bin'. I wonder what the pinout for the 50 pin connector is? I'm planning to wire this connector up to a compact flash adapter. These things are rare enough that I'm not gonna bother trying this as a PCB project type, just wire it on direct to this weird connector:
The attachment IMG_3274 (Custom).JPG is no longer available
it looks pretty good inside so I'll give it a test run tomorrow - someone removed the NIMH bios battery a while ago and it's not corroded in there, but I do think a drink like coffee got spilled on it.
Reply 46746 of 56770, by appiah4
BitWrangler wrote on 2022-10-19, 21:55:
IIRC the bridge chip is on the back and that cooler is mostly for silence.. I believe I own a 4650 AGP as well.
Reply 46747 of 56770, by berenyi_kft
appiah4 wrote on 2022-10-19, 23:56:
Indeed the bridge chip is on the back with a piece of thermal pad on it, my AGP 3850 keeps crashing while running more intensive games and it's most likely due to that chip frying itself, I'll have to see if the 4670 fares any better in this regard
Sound: Audigy 2 ZS
Reply 46748 of 56770, by chrismeyer6
berenyi_kft wrote on 2022-10-20, 00:32:
Back when these cards were new a friend if mine was having that issue. So installed a small heatsink for ram chips and that card never acted up again. These heat sinks are cheap and it's a worthwhile mod.
Reply 46749 of 56770, by TrashPanda
You can solve this by putting a heat sink on the bridge chip, it does require shaving down the thermal pad but adding a heatsink to the bridge chip is worth it, I have a 4650 AGP that I had to do this to.
Reply 46750 of 56770, by Baleog
I finally got hold of a ZX Spectrum in really good condition. It even has the original plastic protection on the keyboard. I may be peeling that off. It however doesn't have the original outer box. I'm usually not so fussed about original packaging but in this case i may consider reproducing it.
Mixed PCs - Midi racks - Micros and more
Reply 46751 of 56770, by mrfusion92
This keyboard and a serial mouse.
That is a Cherry D-91275 AT keyboard with italian layout. It's fantastic, just needs a bit of cleaning.
The attachment 20221020_130944_2.jpg is no longer available
The attachment 20221020_130951_2.jpg is no longer available
The attachment 20221020_130956_2.jpg is no longer available
The attachment 20221020_131008_2.jpg is no longer available
Reply 46752 of 56770, by Nexxen
Nexxen wrote on 2022-10-18, 15:58:
Bought a socket 423 GA-8IDX3 (rev. 1.x) board. Seller said it has stability issues. I can count 4 of those issues :) if it the B […]
Seller said it has stability issues. I can count 4 of those issues 😀 if it the BIOS I can desolder and flash + add a socket for future stuff. It has dual bios, really easy.
https://www.gigabyte.com/Motherboard/GA-8IDX3-rev-1x/sp#sp
Seller's pic.
Replaced 4x 6.3V 3300µF
Socketed the PLCC32 BIOS chip.
Flashed latest bios version F4.
Board came with a custom version F3b with a pic for "Olidata" computers. But all else was just the same as new F4.
I'll benchmark at a later date. Happy to have a working board.
There is just the black goo on the cpu (original thermal compound) that I need to clean.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 46753 of 56770, by gerry
Baleog wrote on 2022-10-20, 09:53:
looks in really good condition, like we were in 1982/3 again 😀
Reply 46754 of 56770, by OMORES
This Philips sound card which uses a repainted CMI8738 chip. I'm curios if the drivers are better in DOS...
Edit: It looks like there are no official DOS drivers. I guess those from C-Media might work.
On the other hand, this card still has a valid page with drivers and everything: https://www.philips.co.uk/c-p/PSC604_00/-/support
My latest video: NT 4.0 running from M.2 PCI-E AHCI SSD.
Reply 46755 of 56770, by liqmat
I never had one of these, but I know they were very popular. It absolutely amazes me how many new games are produced for the ZX Spectrum, every year, to this day. Nice find!
Reply 46756 of 56770, by gmaverick2k
a poormans amstrad cpc 😜
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Reply 46757 of 56770, by Kahenraz
I have a couple of ZX81s. I don't care for the garish colors of the spectrum, so its precessor is interesting enough for me.
Reply 46758 of 56770, by BetaC
Kahenraz wrote on 2022-10-20, 19:52:
If only said predecessor had a keyboard that wasn't, well, holes with rubber in them.
Reply 46759 of 56770, by BitWrangler
Mid to late 80s when you could pick it up cheaper, I had both a ZX81 with an external keyboard, think it was by MGT, unfortunately, it blew the ZX81 up, because prev owner had put too long a cable on it. Was a lot nicer for typing while it lasted. It wasn't super great though, only kinda cash register button quality. Then also I got a Spectrum Plus 48k which had plastic over rubber dome so it was a glimpse of the future! That was also a lot better for typing on than the stock 16/48k one, but would rank among the lower end of rubber domes today. Bought a load of microdrive kit, drives, interface 1s, pile of cartridges, but I could never get the microdrives to work. The rest of the interface 1 seemed functional, could connect to another machine at a screaming fast 19,200 baud over serial. I started futzing around trying to get a linux termcap type right for it, didn't get very far though.
edit: In case you are wondering, all of that had to be abandoned in the late 1990s. I believe the relative I left it with sold some of it to an enthusiast though, as I had preserved it past the first frenzy of junking due to obsolescence and ppl had started to be interested again. So maybe my Sinclair hoard lives on somewhere.
