First post, by k9cj5
I have a dell XPS T450 currently running BIOS version A04 and I was thinking about upgrading the bios the latest version. The currently it has its stock cpu a p3 450. I was hoping to put a Pentium 2 233 to see if I could get better DOS compatibility but when I tried to boot with it installed I got nothing. After reading up a bit on other forums it looks like this motherboard should support a Pentium 2, or even a Pentium 3 up to 1GHZ with a bios update so long as the FSB is 100MHZ. So my goal would be to swap out the p3 450 with a Pentium 2 233, and potentially a Pentium 3 in the 600-900 MHZ range.
The number on the motherboard is
0005335T-12461-98A-009S
AA 722394-109
And I'm pretty sure this is the motherboard it has
https://theretroweb.com/motherboards/s/dell-d … -xps-t___-t___r
These are the BIOS files I could find but I have no idea if these are correct. It specifies that this bios is for the R not the T series.
1.
Flash BIOS Update for Dell Dimension XPS R systems.
https://www.dell.com/support/home/en-us/drive … ode=dimension-r
2.
https://downloads.dell.com/bios/
The one I think would work from this list has the following name and is towards the bottom of the list.
10/31/2000 11:26 AM 431239 xpst_a11.exe
Do you think any of these BIOS files would work? I would hate to brick this awesome machine. Thank you so much for your time and responses.
Reply 1 of 11, by Horun
A quick search took me here: https://www.dell.com/support/home/en-us/drive … ode=dimension-t
Also: not sure you can run a 66mhz bus CPU (233Mhz or 266Mhz) according to the Dell manual, lists only 100Mhz bus cpu's. The SE440BX-3 Intel Tech Prod Spec says 66Mhz or 100Mhz bus....
Reply 2 of 11, by k9cj5
Horun wrote on 2022-12-11, 15:33:
Nice find! That does appear to be the same bios in the 2nd link but I would feel more comfortable using the one you found. Thank you! Also you are 100% correct. The Pentium 2 266Mhz cpu I picked up does have a fsb of 66Mhz. Looks like the slowest p2 with 100mhz fsb is the 350. I might try that. No idea if it will work better in dos but might be worth a try.
Reply 3 of 11, by PC Hoarder Patrol
k9cj5 wrote on 2022-12-11, 20:13:
Nice find! That does appear to be the same bios in the 2nd link but I would feel more comfortable using the one you found. Thank you! Also you are 100% correct. The Pentium 2 266Mhz cpu I picked up does have a fsb of 66Mhz. Looks like the slowest p2 with 100mhz fsb is the 350. I might try that. No idea of it will work better in dos but might be worth a try.
The file @Horun linked is the one I used to update the BIOS on my board - works fine with a 1GHz P3
237.66 KiB
Reply 4 of 11, by Meatball
I'm going to guess the SE440BX-3 behaves like the SE440BX-2. If this is the case, look at the bottom right corner-edge of the board next to the onboard speaker. There's a jumper there. You need to set that properly to install a Pentium II, first. I think it's set 1-2; move it to 2-3 (or vice versa). Install the Pentium II, power on, and a menu pops up (or it may be available in the BIOS once you enter it; I can't remember exactly as it's been a while). Select the 233MHz option. Move the jumper back to 1-2 when finished and powered down. Powerup after the jumper is back to the default position, and you should be good to go from this point forward.
Reply 5 of 11, by Horun
Good to know ! Here is the extracted pages from 440BX-2
Reply 6 of 11, by k9cj5
Meatball wrote on 2022-12-11, 21:15:
I dont know if I tried this or not when I installed the p2 266 the first time. Do think its worth tryin again? Or will this board only work with 100MHZ fsb cpus's? Thanks again for everyone's responses.
Reply 7 of 11, by k9cj5
PC Hoarder Patrol wrote on 2022-12-11, 20:37:
[/quote]
[/quote]
The E139761 number near the cmos battery matches mine and the layout is the same. So its a SE440BX-3. Good to know. Also thanks for letting me know that bios also worked for you. Question, did you get your on board audio to work? The onboard Yamaha YMF724F-V seems like it would pair nicely with native opl3 support but I cant seem to get mine going. Wondering if you had any luck with yours.
Reply 8 of 11, by Meatball
k9cj5 wrote on 2022-12-12, 03:01:
That depends how badly you want to run with a Pentium II. It doesn't hurt anything and takes a few minutes, otherwise.
Reply 9 of 11, by dormcat
Check the entire set of drivers for your Dimension XPS T___ series as the list contains hardware that might match your computer; this would reduce the chance of misidentifying your model.
I found driver for Number Nine Motion 771 (S3 Vision968) of 1995 and BIOS of 1996 for my Dimension XPS P___c MDT (bought in 1995 and currently the oldest functioning computer in my collection) on their website; I have to give Dell a thumb up for archiving so many drivers for their legacy products. The only other company maintaining a similar database is Lenovo / IBM.
Reply 10 of 11, by Horun
Yes I would try it, follow the instructions in the 440BX-2 pdf . Do not flash the BIOS before trying it. Some times they remove older CPU support to add newer.
k9cj5 wrote on 2022-12-12, 03:03:
Others here also have had trouble with the on-board audio. Seems the YMF724F-V is more for "add-on" PCI cards than built-in. Check this topic:
SE440BX-3 YMF724F-V 98SE driver refuses to install
I did not see the Yamaha driver in the list from Dell for your model. Not sure why..
https://www.dell.com/support/home/en-us/produ … nsion-t/drivers
Reply 11 of 11, by Horun
dormcat wrote on 2022-12-12, 03:50:
Agree !! They still have drivers/stuff for my Vostro 1500 laptop last time I checked.
