First post, by k9cj5
I have a dell XPS T450 currently running BIOS version A04 and I was thinking about upgrading the bios the latest version. The currently it has its stock cpu a p3 450. I was hoping to put a Pentium 2 233 to see if I could get better DOS compatibility but when I tried to boot with it installed I got nothing. After reading up a bit on other forums it looks like this motherboard should support a Pentium 2, or even a Pentium 3 up to 1GHZ with a bios update so long as the FSB is 100MHZ. So my goal would be to swap out the p3 450 with a Pentium 2 233, and potentially a Pentium 3 in the 600-900 MHZ range.
The number on the motherboard is
0005335T-12461-98A-009S
AA 722394-109
And I'm pretty sure this is the motherboard it has
https://theretroweb.com/motherboards/s/dell-d … -xps-t___-t___r
These are the BIOS files I could find but I have no idea if these are correct. It specifies that this bios is for the R not the T series.
1.
Flash BIOS Update for Dell Dimension XPS R systems.
https://www.dell.com/support/home/en-us/drive … ode=dimension-r
2.
https://downloads.dell.com/bios/
The one I think would work from this list has the following name and is towards the bottom of the list.
10/31/2000 11:26 AM 431239 xpst_a11.exe
Do you think any of these BIOS files would work? I would hate to brick this awesome machine. Thank you so much for your time and responses.
