Want to build a DOS/Win98 Gaming PC
Reply 20 of 27, by Bruno128
bogdanpaulb wrote on 2023-04-10, 12:32:
there a plenty of socket a boards with the same issue (agp gart issues)
While there are indeed fast-writes and GART troubles on some SiS and Via chipset/bios combos from s462 times, what I was referring to is a peculiar win98-specific GART problem sighted on s754 with VIA chipsets. (see this post by user Repo Man11)
Now playing:
The Dig: 1995 VLB 486
Arcanum: 2003 Acrylic build
SBEMU compatibility reports list | Navigation thread
Reply 21 of 27, by bogdanpaulb
Bruno128 wrote on 2023-04-11, 00:22:
I see no problem, from ~10000 points with a Intel D925 in winXP to ~9500 points with a Sempron 3100+ in win98SE. It's the same videocard. The s754 board has also the latest bios installed (F12).
Reply 23 of 27, by bogdanpaulb
Bruno128 wrote on 2023-04-11, 08:11:
bogdanpaulb wrote on 2023-04-11, 02:01:
That's interesting. What is the board model?
It's stated in my first post, Gigabyte K8VT800M rev.1 which looks like a Gigabyte K8VM800M rev.1 and the K8VT800M rev.2 looks the same as a K8VM800M rev.2. The rev 2 of those boards looks different in the cpu vrm , have no place on the board for the optional firewire controller and have the VT8237R SB (rev.1 has the VT8237). My board came (for cheap) with a defective vrm (upper mos on stage 1 shorted and was shorting again after replacement/power up so i had to replace the HIP6602BCP driver also).
Reply 24 of 27, by Joseph_Joestar
I see no problem, from ~10000 points with an Intel D925 in winXP to ~9500 points with a Sempron 3100+ in win98SE. It's the same videocard. The s754 board has also the latest bios installed (F12).
The issue described in that thread doesn't affect every single Socket 754 motherboard with a VIA chipset. From what we've seen so far, it varies based on the chipset type and BIOS version. This was investigated quite thoroughly by @bloodem and described here.
The easiest way to test for the bug is to dual boot Win98SE and WinXP and then run 3D Mark 2001SE, using the same (or very similar) driver version on each OS. If the bug is present, the score under Win98SE will be halved compared to WinXP. It can also be checked by benchmarking games like Quake 2 on each OS and comparing the results. In that case, the difference is most noticeable in lower resolutions like 640x480.
Reply 25 of 27, by bogdanpaulb
Joseph_Joestar wrote on 2023-04-11, 13:09:
Probably they changed the design of the motherboards to be able to use K8T800 PRO chips that didn't make it (flaws in the silicon die) so they don't have to scrap them and to replace the K8T800 ones when the stock was out.
Reply 27 of 27, by Shagittarius
DocBo wrote on 2023-04-18, 15:02:
https://youtu.be/putHMSzu5og
What about this? Is this an alternative choice to an real ISA Slot?!
Looks like its only gaining you a few further generations to work with and you need to do so much work to get it set up. Also it looks like there are issues as demonstrated by Quake and Lemmings. Since you can max out all dos games with MBs that actually support ISA natively I really don't see much of a benefit to this.
