First post, by HansZ
Hello to all,
I have ZIDA 4DPS rev 1.0 (without the PS/2 connector) and trying to have working serial mouse. Ports are enabled, mouse driver is installed however mouse doesn't respond. I'm 100% positive its the issue with the com port cable. Does anyone knows correct pinout for this motherboard? Much appreciated, thanks
    226.28 KiB
    168.28 KiB
Reply 1 of 2, by bogdanpaulb
There are 2 versions of serial pinouts, open the serial brackets that you have used and check if they mach, if so, try with the other type.
    26.76 KiB
