Reply 24400 of 27785, by RedSarg99
ubiq wrote on 2023-05-27, 01:38:RedSarg99 wrote on 2023-05-26, 19:34:it is a nice clean build!
Which PSU are you using and do you get enough molex/fdd connectors on it?
Also you added a seperate card for EIDE?I'm using the NZXT C850 that I got with the case. Totally overkill, but at least I know it will do everything i will (ever) need. Fully modular, so I just plug in whatever cables I need. I keep a bunch of SATA to floppy power adapters around, very handy.
And yeah, I added a Promise FastTrak 100 card, mostly just so I could use those nice black ASUS 80-pin cables. With my BF6 mobo by itself I would have had to use some gungy old grey 40-pin cables. 😅
I thought I had one of those cards before, and lo behold I found a driver CD for it! Must have had it a few years before selling it off.
