First post, by Shponglefan
- l33t
There's been a lot written about the efficacy of retrobrighting, whether it's worth it, potential damage to plastics, etc.
In digging around on this subject, I came across a post at VCFED:
I have mentioned this on other posts, by far the better method to correct the yellowing is to re-coat the surface with a protective layer. But of course everyone's first thought is, what ? Paint, it will ruin everything and flake off.
Well it will not if the right kind of paint is used, because it chemically reacts with the surface and etches its way into the surface in the minutes before it dries (yes minutes). It then creates a new plastic surface, just as durable and scratch resistant as the original surface, Plus you can select the shade of white or off white you require for a perfect match to the original. The paint that works in this mode for all vintage computer plastics is Holts Duplicolor, a fast drying automotive lacquer. Even if the original plastic surface was textured, it still works with a thin coat and the texture remains. When you scratch the surface you will find it has "becomes one" with the original material and doesn't sit as a layer waiting to flake off.
https://forum.vcfed.org/index.php?threads/ret … ly.75417/page-2
I've been long curious about painting cases. I've done a little bit of minor airbrushing one case to hide some cosmetic repairs to the plastic. This was using acrylic model paint which worked fine, but obviously wouldn't the durability of lacquer paint.
I don't think I've seen any examples of airbrushing cases. All examples I've seen of painting cases involve spray painting. However, spray painting limits the color options and risks applying paint too thick eliminating underlying texture. With airbrushing one can control both the color mix and apply thinly layer coats to preserve texture. The idea of lacquer paint bonding with the surface in a way to effectively add protection is also appealing.
I'm curious if anyone here has attempted airbrushing and in particular using lacquer paints. I have a couple older, damaged cases that I might use as a test material for this.
