First post, by pavel.sedina
Hello esteemed community,
I hope this finds everyone well. I've recently acquired a Toshiba T1910CS, which works beautifully, except for the floppy drive. As a backup solution, I purchased another T1910CS for parts, hoping that its floppy drive might be functional so I could swap them out.
However, if this solution doesn't pan out, I'm curious about the options available for reinstalling the DOS operating system and transferring data onto the laptop. Given the limitations of this older model, I wanted to seek advice from the experienced experts on this forum.
Additionally, I'd like to inquire if there exists any form of an external sound card or audio solution compatible with the T1910CS. I'm interested in enhancing the audio capabilities of this vintage gem.
Your insights and guidance would be invaluable. Thank you in advance for your time and expertise.
Warm regards,
Pavel
